I have the Modifry ECT (1 or Original) wired up to the stock K20A ECT sensor but it is reading backwards on the cluster (starts off full hot then goes down to 2-3 bars when actually hot). I've already emailed Bob at modifry and he said he can change the calibration on the unit but I need to send him some readings off of the sensor. Has anyone else had this problem?
I tried using the single wire sensor (on my k-tuned coolant housing) also but it didn't read that one at all. I've also browsed through every s2000 cluster swap thread and have only seen one person mention the same thing but never talked about a solution. Let me know if you've experienced the same thing and had it fixed or if you've just left it as is. TIA
