1 - 13 of 13 Posts
S2 Springs & retainers, Stg1 cams, Int Valves Blueprint Pro K20 rods, CP 86mm pistons
cp pistons 86mm 9 compression With only 1800miles
Perfect condition (i sold my block.)
300$
BluePrintMfg Super turbo K20 rod good enough for 800-900hp.
Teflon coated with arp. Only 1800miles.(i sold my block) $390
Skunk 2 Stage 1 Cams with only 1800 miles. Perfect condition $320
Skunk 2 Springs & Retainers with only 1800miles k20a2. Perfect condition 190$
Standard size supertech intake valves and... stock exhaust valves
also GIFT 12 SKUNK2 FORGED high compression valves
Everything...perfect condition 200$:)
Blueprintmfg Cams stage 1 ====>400$
Discussion Starter · #10 ·
Re: Skunk2 Springs & retainers, Stg 1 Cams, Intake Valves, Blueprintmfg Pro H Beam Ro
What version are the cams? Are the springs tuner or pro series and are the retainers the titanium skunk2 ones?
The cams are the first version and i have sold 3 couples of the same with no tensioner problem.TUNER series valves springs and TITANIUM retainers skunk2.
(The tuner series is better than the pro valve springs because it is not so stiff and makes more power.)
1 - 13 of 13 Posts
