ok so i just put my motor back together with my upgraded parts (IPS K2's, supertech springs and retainers, Ferrera valves, CC stg 2 clutch etc. )..made sure everything was put together properly and to spec....put the motor back in the car and cranked it...NO LEAKS, so thats great, but wen i plug it into my k-pro after loading the IPS basemap, i get an a/f between 25 and 33
and a rough idle (which i guess is expected with cams)
here's some issues i ran into along the road, my brother lost the 2 bolts that connect my test pipe to my header, and my friend pulled out the plug for the o2 sensor exposing the little cables...
now, at first, we thought it was an exhaust leak because we just used regular bolts with no springs and tighted the shyt out of them to make sure there was no leak, but it only brought it down from 33 to about 25 ish....
so now im guessing that my friend plugged in the small tabs that go into the o2 sensor plug in the wrong sequence, but he swears he put them in properly...
and im pretty sure that if the car's a/f was ACTUALLY that high, it wouldnt even crank or it would pop...so thats what leads me to believe its the o2 sensor, but again, he swears he put it back properly..
so now im stuck, i dont know whats wrong with it, scared as balls to drive it with it being so lean, ANY SUGGESTIONS???
thanks in advance
thanks in advance
