1 - 20 of 28 Posts
Getting rid of some of the other stuff laying around the garage after the selling of the Motor/Trans and stuff. Pretty basic stuff here but please make sure you READ everything posted about the item you want to purchase. Some of this is listed for shipping and some I will NOT ship due to size. My location is listed at the bottom of the page, I am not located in "Soviet Russia" as my info to the left states. :p
First up, And probably the first to go...
RSX-S Shifter Box w/ Cables + Karcepts Box and Hardware
SOLD SOLD SOLD SOLD SOLD
Price:
Next up,
Sparkks racing EG K-Swap conversion Harness
This harness is unique in a few ways, so read up.
-INCLUDES OEM plugs for brake light, Coolant Temp Sender AND O2 sensor!!!
-This was an EARLY harness so some of the wires aren't the right color so they're labled with tape. Pics show this.
-Came from a KNOWN WORKING swap! You KNOW it will work!
-Includes install instructions, Provided I can find them... (If not I'll bother Corey for a set of them)
Wide shot, whole harness
Coolant temp sender and Brake light plugs
O2 sensor plug(I only used one, all you need)
The orange wires are labled with yellow/red tape to show correct colors.
Pricing:
-$200 Picked up
-$210 Shipped
Next up,
Hasport EGK1 Mounts (Slightly Damaged...)
Price:
Next up,
EG LOOPED P/S Rack, Makes it a MANUAL rack
This is the P/s rack that came out of my car. It has been converted to MANUAL via looping of the High/Low pressure lines. Sadly this CANNOT be converted back to power steering due to me JB welding one of the holes shut because it cracked trying to plug it. Still a GREAT Manual rack.
-Nearly NEW Outer Tie-Rods(10k on them, if that)
-ONE Nearly new Inner-Tie Rod(10k on it, if that)
-Other Inner has Approx. 40k on it, Still in great shape
-Replaced boots 20k ago(they're two piece but work great)
Full shot
Close up of Looped line and Blocked off Port
Price:
-$175 PICKED UP ONLY, WILL NOT SHIP!
Last up,
Thermal Research and Development Exhaust for EG Hatch(Modified)
This is my Thermal R&D Exhaust system I modified to fit into my car. The begining transition off the header is a 3-bolt and is 2.5" it then steps up to 3" through a reversed reducer that is clamped on with T-Bolts. This will BOLT UP to an EG hatch with a K-series that is using the DC SPORTS swap header. any other header will need modifications. The underside of the car WILL need some "clearancing" to fit this due to being 3" and slightly custom. I had to hammer some heatshields out of the way but it DOES fit.
-Chopped tip off Muffler for sleeper look
-Flat Black'd Muffler Canister for sleeper look
-Comes with hardware/gasket/hangars.
Full shot, entire system
Close up of one mod, Cut/Shortened and JB welded Walker Clamp.
Close up of second mod, Cut/Shortened 2.5" section is JB welded, Transition is NOT.
Price:
- $350 PICKED UP, WILL NOT SHIP!
(add up what you're getting...this is a $600+ exhaust NEW)
That's everything for now, I may add some other things later on. If you're weary about buying from me online please do not be I have PLENTY of people that will vouch for me and I have lots of feedback from plenty of places.
My info:
-I am Paypal verified with 150+ Positive transactions
-I have 100+ eBay feedback all 100% positive.
-I have been a supporting member of this site 2 years running
Contacts:
PM: Click my name, PM me here.
AIM: CGZcustoms
For items being picked up...
- I AM LOCATED just outside of BEL AIR, MARYLAND
That's all for now, Thanks for looking!
-Froth
Bump.
-Froth
Bump.
-Froth
Shifter Box, Mounts and Harness all pending. Will update thread if sold/not sold.
-Froth
Topside. ALL items still available as of right now!
-Froth
Discussion Starter · #7 ·
Bump Again.
-Froth
Discussion Starter · #8 ·
Topside, Everything still available! BUY BUY BUY!!!
-Froth
Discussion Starter · #9 ·
BUY THIS, NOW! BUMP!
-Froth
Discussion Starter · #12 ·
Responded to PM's - UP! BUY BUY BUY!
-Froth
Discussion Starter · #13 ·
Bump.
-Froth
Bump!
I broke a Hasport mount once, I sent them the broken one and they sent me a new one free of charge! Great deal for someone willing to wait on a new one!
Discussion Starter · #15 ·
Bump!
I figured that was the case, I'm just too lazy to bother with all that.
-Froth
Discussion Starter · #17 ·
PM'd back.
-Froth
Discussion Starter · #18 ·
A LOT of intrest in these items, but NOTHING solid yet. Everything still available.
-Froth
Discussion Starter · #19 ·
Shifter Box setup SOLD, Everything else still available. Lets get this stuff moving!
-Froth
Discussion Starter · #20 ·
Bump.
-Froth
1 - 20 of 28 Posts
