1 - 4 of 4 Posts
try using a power rerouting wiring harness...basically a harness which connects directly to your battery and has relays and fuses external of the oem wiring.
only thing that your stock wiring harness will do is control the relays...
www.xenonpros.com has a relay harness for $50 or so...
that will take out the fuse issue
ok i did a hid and headlight assembly set in an 06 rsx base.ok head lights are aftermarket assemblies and a 12v 35w hid kiti keep blowing fuses for the lights also the halos and leds dont work why is that does anyone know or has anyone had this type of problem
I see so relay will solve my case thank you for the input dude. I hope this work for me. If power rerouting will not work i will just leave it to the mechanic and suffer paying labor cost. I don't wanna have electrical wiring problems in my car.
1 - 4 of 4 Posts
