1 - 6 of 6 Posts
rsx dash in crx
We just swapped the k20a into a crx with the hasport mount kit. But we are also using the rsx dash. We have the dash in and it fits nicly with a lil trimming here and there. it is actually shorter in length than the crx dash but is deeper width wise. But with using the dash that means having to use the full rsx wiring harness. So that means having to use the gas tank also right?? in order to have the gauge read fuel? has anyone attempted this before?? we have the rsx gas tank installed but we had to cut out the floor to make it fit. Now we need to figure out a way to make everything look right, and also make it safe. Any help on anything would be appreciated hopefully i will get some pics up, so you can see exactly what we are attempting. thanks!
you guys got those mounts quick... any engine bay shots?
what throttle cable are you guys using? where did you run the shifter cables thru? also what kinda radiator are you using? radiator hoses?
Not too difficult. just took a few times cutting and fitting in the back and corners, then taking it out and re-fitting it. The heater box fits but you have to make the hole bigger in the fire wall at the stock location for it to fit. but all in all that and the motor were the easiest parts. most of the stock bolt locations fit also.
1 - 6 of 6 Posts
