1 - 2 of 2 Posts
Well I just got my axles back in and now Im trying to get the calipers back on. I have brand new rotors and just swapped in new pads. When I tighten the two strut bolts on the top and bottom of the calpier the rotor shifts and does not lay even.
You can see in the pic that the right of the rotor is slanted more than the left. The more I tighten, the worse it gets. Something may have bent because now its hard to even get the rotor onto the stud bolts. What could be causing this? I need help!
1 - 2 of 2 Posts
