1 - 7 of 7 Posts
I have the RSX Helms. I am building a K24A4 and using TSX rods. In the RSX Helms there are 2 specs for bearing color. One for the K20A2 and one for the A3.
Is the A3 bearing size the same as the TSX/K24A4 combo or do I need another reference? Thanks
In the General section you have the TSX manual shop...
But I have the same trouble...
I gonna build a k24a1 bottom...
but only the k24a2 manual shop... I don't know if the have the same journals diameter....
when I take a look at hondapartsdeal and acuraoempart.... the Honda CRV beargins cost around 3$ each... and the TSX something near 9$.... why?
Discussion Starter #4
In the RSX helms:
Rod Big end bore size; A3-48mm A2-51mm
I will measure the big end of the TSX, If its 48mm I will use the A3 spec, I can't find the crank journal size, just service limit for run-out etc... and I no longer have the K24A4 rods to check, although I do have the old bearings that could give me a clue to the size. I just wish that the honda color code had a deffinitive size cross reference.
I have a chart showing the color-size correlation. I will have to drop by the shop to get it and I will post it up then.
All the K24's use the larger rod bigend bore.
Blue 2.013-2.010 mm 0.0793”- 0.0791”
Black 2.010-2.007 mm 0.0791”- 0.0790”
Brown 2.007-2.004 mm 0.0790”- 0.0789”
Green 2.004-2.001 mm 0.0789”- 0.0788”
Yellow 2.001-1.998 mm 0.0788”- 0.0787”
Pink 1.998-1.995 mm 0.0787”- 0.0785"
Red 1.995-1.992 mm 0.0785”- 0.0783”
Rod bearing thickness by color
Blue 1.510-1.507 mm 0.0594”- 0.0593”
Black 1.507-1.504 mm 0.0593”- 0.0592”
Brown 1.504-1.501 mm 0.0592”- 0.0591”
Green 1.501-1.498 mm 0.0591”- 0.0590”
Yellow 1.498-1.495 mm 0.0590”- 0.0589”
Pink 1.495-1.492 mm 0.0589”- 0.0587”
Red 1.492-1.489 mm 0.0587”- 0.0586”
Ok so all K24 have the same Journal diameter ?
Discussion Starter #7
Many thanks. Just to be clear, The top section is main sizes and the bottom Rod sizes.
Thanks again, good stuff.
1 - 7 of 7 Posts
