It is not a necessity but some recommend it.I have the aftermarket valvetrain and do hit the road tracks. So doing the s2000 oil pump might be a necessity then?
But this on the 1320, yes? I was speaking of road racing. The A2 pump can have some issues under high G load at high rpm.It is not a necessity but some recommend it.
MarcP takes his EG with a Stock A2 oil pump to 9800rpm Every pass he says.. Never had a problem.
Yes the 1320. Okay thanks for clearing up that you were speaking about road racing..But this on the 1320, yes? I was speaking of road racing. The A2 pump can have some issues under high G load at high rpm.
OP: curious... what cams do you have?
stiffer springs, titanium retainers, s2k pump for insurance since it is road racing, baffle, and accusump(optional but I recommend it).If my cams are still making power at 9.5k rpm, what else would I need to rev that high? I currently have forged pistons, I-beam rods plus crankshaft has been balanced to 10k rpm. Would the stock oil pump work fine?
Nice, what kinda simple mods are we talking about? Having to change to the k24 oil pan is really putting me off from changing to the s2k oil pump. Will probably stick with the A2 oil pump.Some simple mods to the A2 oil pump will allow it to operate as well as the S2k unit for road racing. And there are benefits to the A2 pump, you can retain the cast aluminum pan and there are commercially available baffle kits, whereas the S2k pump will require the stamped steel pan and a totally custom baffle setup.
It may for a few passes, but valve float happens around 9200-9300 on the K20a's...You might squeek by with a few passes but sooner or later it WILL fail. Upgrade the valvetrain, I went to Supertech 92lb Seat pressure springs and Ti-Retainers for which the combo is rated at over 10k RPM just for my own personal piece of mind.Just wondering, but would a stock K20a head hold up to a 9500 rpm rev when runnin the 1320's? Thanks
Start with a new A2 pump with the latest revisions. then open up the pump and using a dremel smooth the transition point where the oil passage makes the turn to enter the block, smoothing this transition from the cast formed passage to the drilled passage helps tremendously. Or you could purchase the pump pre-worked from Hytech.Nice, what kinda simple mods are we talking about? Having to change to the k24 oil pan is really putting me off from changing to the s2k oil pump. Will probably stick with the A2 oil pump.
Cool cool, thanks for the good info:up:It may for a few passes, but valve float happens around 9200-9300 on the K20a's...You might squeek by with a few passes but sooner or later it WILL fail. Upgrade the valvetrain, I went to Supertech 92lb Seat pressure springs and Ti-Retainers for which the combo is rated at over 10k RPM just for my own personal piece of mind.
-Froth
