The most important new addition: fastenings for side attachments have been applied to the tubular frame, allowing better positioning on the shell. A hole has been made in the bottom for the passage of the fifth and sixth point of the seatbelt. The completely renewed style has been enhanced with visible quilting, contrasting with the basic fabric.
If you have any questions you can reply to this thread, send us a pm or use the contact us page on our website.
Sparco Seat Bases mount to the factory holes in your vehicle's floor and provide a flat surface for mounting your SPARCO seat. In order to properly install a seat in your vehicle, you will need one (1) of each of the following, per seat:
Sparco Seat Bases mount to the factory seat mount holes in your vehicle's floor and provide a flat surface for mounting your SPARCO seat. In order to properly install a seat in your vehicle, you will need one (1) of each of the following, per seat:
-Seat Base (either ‘600’ series)
-Hardware Kit (50001)
-Track Set (00493)
*The Track Set allows for forward and backward adjustment of the seat
**BASES MAY DIFFER FROM PHOTO DUE TO MAKE/MODEL
***The Track Set is not necessary for installing a seat, but does allow for forward and backward adjustment of the seat, and is therefore recommended***
Designed in conjunction with the top World Rally Championship drivers, this competition seat offers maximum lateral support. Its unique design will provide the most demanding of drivers with the ultimate in safety and performance. Side mounting only.*
FIA homologated
Pricing is per seat.*
With temperatures that can reach 130 degrees in the cockpit of a racecar, a driver can loose up to 10 pounds in fluid loss during a 3 hour race. Dehydration can impair a driver’s ability to concentrate and focus during long stints. The Sparco Rally Drink Bag will help combat the negative effects of dehydration. The Rally Drink Bag attaches to the back of any Sparco competition seat. It features a specially designed insulated pouch that holds 2 liters of water. The drink tube can be attached to the Shoulder harness to keep it properly located for easy access. It also features extra pockets for carrying small items.
Attach to any Sparco competition seat
Insulated pouch holds 2 liters of liquid
