1 - 16 of 16 Posts
Re: FS: Built allmotor short block 2.0 b20vtec.. Darton Sleeved
Sleeved 2.1 liter 87 mm DART Block
-Weisco Pistons, gas pistons, high compression, 14:1 compression
-eagle rods
-arp rod bolts
-arp main bolts
-brand new piston rings
-brand new rod bearing
-perfect dart sleeves, no scratches,
-new itr water pump
-new itr oil pump
-new seals
-balanced and blueprinted
-built by the best engine builder in utah
-capable of 280 whp all motor. you will run 12's with this block in the right car.
-guarenteed
-engine is dry of oil, never been started.
-100 octane suggested. :p
-over $3000 in parts and labor.
NOTE, Head Studs Not Included.
pickups welcome, or pallet shipping, P.S. make sure you have a business address that i can ship a pallet to.
$1100.
Discussion Starter · #7 ·
Re: FS: Built allmotor dart short block 2.0 b20vtec
Where are you located? Do you need any K parts as trade? I have 2 k20 blocks + sleeves (not installed), f23 crank.
located in utah.
i don't need any k parts. i actually only need money for bills.
if you have stuff to trade, i would only be reselling it so i don't want to trade for heavy car parts.
-eagle rods
-arp rod bolts
-arp main bolts
-new itr water pump
-new itr oil pump
-new seals
-guarenteed
$1500.
Hi I'm new so I could be mistaking here.
This is an awful cheap price for a nice looking short block like this.
From what I see here, the DART block looks nothing like your block.
Dart has thicker decks, DART logo cast into the side, (your block has OE serial number pad) Dart has an extra stud mount cast near the top of cyl #2 (OE Honda does not), Dart stud mount near the top of cyl #1 is not ribbed (the OE Honda one is). There's many other differences between your OE looking block and the Dart casting. A sharp eye can easily see. I've added pics for comparison.
Also confusing is why would anyone take a sleeved Dart block and resleeve it all over again?
Again it's a nice setup, but Dart?
it's a typo.
it should have read darton
There is a pretty BIG difference between a DART block and an Darton sleeved block..
Title has been edited to display correct information
1 - 16 of 16 Posts
