1 - 20 of 37 Posts
Here is the same intake mani's on a straight line
Looks to be 1 inch lower :thumbup: I think it will fit now :eek:
milled the flange eyy.. does the hood clear now? how much and what angle you do on the flange? looks good.
Its machined from nothing on the top, to half think on the bottom flange... I havent tested it yet, but people are getting it to work with washers on the mounts, and hood hinged... so i think a inch lower plenum will be good enough... and I have to cut the hood a bit more:up: Ill post if it closes soon enough.
i've been wondering what the effect on power would be from changing the angle of the airflow by doing that
sweet, in for the results.:up:
Discussion Starter #11
Ya, im gunna shave all the useless stuff off the intake mani:up::up:
HAHA I am doing the exact same thing, including the mani shave :up: I just came up with the idea a week ago and shaving the flange, If it dont clear still I got a back up plan:)
Discussion Starter #14
I plan to cut the hood a bit more (webbing), and worst case put a washer under the mounts... whats your backup plan?
HONDA HEAVEN RIP
:rolleyes::rolleyes::rolleyes:
your goooooooooooood. your brain never stops! good job.
p.s. the header made 238/176 :dance:
HONDA HEAVEN RIP
instead of washers, since your you, can you have someone make a billet spacer for under the mount? you know like a traced version of the mount?
1 - 20 of 37 Posts
