1 - 5 of 5 Posts
I need u guys help here.As I posted before hybrid is lagging on there radiator kit.So I have to go to plan b. :( So with that said I need info and photo,s of of how anyone did their rad and what about the thermo unit and coolant switch were and how did u guys mount them? thanks!
Discussion Starter · #2 ·
are u guys running hasport parts?I thinking about running a c/r or koyo rad but info would really help?I need to no what some of u guys a useing .I will be starting my swap tomarrow :dance:
its better to get the slimmest radiator posible but also good enough for cooling
what i did was tap out the outer condenser leg and lined it up with the closest radiator leg, its best to do it before dropping the motor and for the fan switch you can just buy the hasport adapter
its a tight fit
1 - 5 of 5 Posts
