So I decided to build a motor for my EP3. Instead of taking the easy way out and just swapping a K20A2 for $1500, I decided I would build a K20A3. I knew I would rather have a rebuilt motor over a used motor that would be more likely to grenade on me at any moment. I figured if I tackled all the weak points of the A3 I would be good. I am using a RSX A3 over the EP3 A3 so I will have the A2 oil pump. Next I am tackling the unbalanced crank shaft by using a K20A2/Z1/Z3 crank shaft. I will be using Eagle rods and OEM A2 11.0:1 or Supertech 11.5:1 pistons. Finally I will be using a K24A1 cylinder head with K20A2 cams and rockers. Also I plan on using Supertech valves and valve springs in the head for added security. I am almost certain I will be using the EP3/RSX-S throttle body and intake manifold for better mid range power. My goal is 200WHP +/- for my build.
*I haven't mentioned every little part I plan to use but this is just a rough sketch.
