1 - 9 of 9 Posts
I have been reading up on alot of the info here, and the one big question i have is with the power steering, i know that it cannot be kept. But what do i put in its place for the serpentine belt to be used. I have heard a EP3 idler pulley, but i am not too sure, and if it is then can i purchase this part at honda and how much. Please enlighten me with ur info, thanx to everyone who answers. I cant wait for this swap to happen.
-Braxton
idler pulley
pulley 31190-PRA-000
bracket 31175-PRA-000
washer 31185-PCX-003
bolt 90031-PRA-000
I would not pay dealer prices...unless you have a connection. I think I priced this out through a large dealership/distributor & it came to around $75-$85
BTW you CAN keep powersteering...you just need custom hydraulic hoses & reroute them[/b] & notch the hood
If i use this pulley can i use the serpentine belt that came on the engine, or would i need to get a different sized belt? thanx for all the input it helps out alot.
-Braxton
-Braxton
If you use the EP3 idler pulley, you need to get another belt that is 50.5 inches long and 7 rib. You can get it at Kragen. I have posted part numbers in the past. too lazy to look right now
ok so i'm not that lazy. here it is:
should be 50.5 inches
I posted this before but you can get the belt at Kragen
The belt part number is 5070505.
the 7 = 7 rib
505 = 50.5 inches
pic of setup(using a stock pulley but the AEM should still work)
Discussion Starter · #8 ·
Damn thank u very much guys, ya'll are really the best. This is a great forum with tons of info and help. Cant say enough great stuff.
-Braxton
1 - 9 of 9 Posts
