Here's a few thoughts. Assuming that there was a way to get the s2000 pistons to work in a k24a stock block....
What would the final compression be? On a CRV longblock? Accord ? Element? TSX? K24a/k20a2 stock frank?
Again, I am not asking how to get it to work. I am just interested in knowing/estimating the final compression.
As far as compression height and pin bore, the K20A &
K24 pistons have 30mm compression height, while the F20C piston is 27.75mm.
Thus you would need a longer than stock K24 rod, or reduce the block deck
height 2.25mm (shudder). The pin bore size for the K20 & K24 is 22mm,
whereas the F20C piston uses a 23mm pin. So you would either need to get a custom rod made or bore the rod 1mm.
Any idea? Guess?
Nikos
Any idea? Guess?
Nikos
