1 - 5 of 5 Posts
since yesterday,my TPS ,after a little rolling, have around 6% gap but it can say 100%
but of course,at low TPS,the engine makes me little jolts!
when i stop the engine,the TPS work corectly:confused::confused:
is the TPS have a prob?do you change them sometimes?
is a Blox TPS is good for the remplacement?how can i change the oem TPS?
thanks a lot for your help because i don't find any topics for that:eek:
Discussion Starter · #2 ·
today,so probs with it!
i was thinking one thing so:
yesterday,it was snowing so,very very cold(-10°C),so,do the TPS sensor could be freeze a little?
i think YES:silly:
Does the percentage read out jump around? You can test the TPS with a volt-meter. Prob it with the key in the ignition position, and open the throttle plate by hand, see if there are any gaps in the voltage read out.
The TPS is known to go out. I replaced mine with the Omni-Power one. Same as the Blox I bet.
You can test the tps in kpro as well. You can also adjust it to make it read 0 - 100 %
the problem has gone!
the TPS work perfect now,also in the KPRO!
test are alright:up:
and friend had the same thing 2years ago,and it was the same thing,the TPS freezed!
because we have put out the cooling in the Throttle!
also,we modify the hood to allow more air when we cruise to keep RBC&TB cold!
but,when it makes -10°C,it s too cold:dance:
1 - 5 of 5 Posts
