1 - 12 of 12 Posts
my car wont start and some one told me that my injectors might be stuck cuz of my motor has been sitting for 6 months does anyone know how to get them unstuck (banging them on the floor)LOL thanks
Honestly.... there may b other reasons why it wont start. I have had my K20 sitting for 6 months and never had a issue...
Check the other possibilities dawg.
thanks ill look it over again but i did start the car with starting fluid, so i started check out my wiring (which should be ok since it is a brand new harness from acura) and it seems to be ok so then i decided to pull the fuel rail with injectors off the intake and i tried to crank the car and only one injector#2 worked so the i thought it was the wiring , but then i decided to see if the other 3 worked so i tested them directly to the battery and they didnt work . So after banging on them i got #1 injector to fire but i cant the other 2 to work
if got any other options let me know (Db8)
Discussion Starter #5
anyone got any other suggestions
got another ? are the k24a8 injectors the same as the k20z1 injectors
I got an extra set somewhere I'd sell you, or overnite yours to RC eng. and get them cleaned and balanced. Just some friendly advice:up:
i believe they are both 310. have yours cleaned and see what happens
Check around your local auto stores, speed shops and the like, see if they know were you can get them cleaned.
so all i got to do is send them to rc or who else can clean them?
most local shops can do a fuel system cleaning which also cleans up the injectors. May not be as good as RC but id try that first
1 - 12 of 12 Posts
