Is the starter turning?
If so, check the fuse as stated above. If the fuse is good, check your wiring. I'm not sure how "Plug and Play" the HASPORT harness is, but if it's like the Hybrid harness, there's possibility of two things: Getting any combiniation of 7 specific wires jumped incorrectly, or getting the incorrect harness for your swap.
In my case, I was sold a K20a harness, my motor is a K20a2. It was an easy fix, but it required someone to lead us through the pin changes on one of the connectors.
Another way to check to see if a map had uploaded to the K-Pro is by keeping the ECU plugged into your laptop and shutting down the K-Pro application. Open it back up. Turn the car to "on". Make sure you have the status of "online" and "Ignition: ON" on the bottom of the screen. Now download the map from the K-Pro ECU to the laptop. If something loads, there will be a file name on the top title bar of the application window.
