Getting everything ready to install into my eg hatch within the next few weeks. The set-up is as follows:
Full Race K-series manifold built for k24 block
Tial 44mm v-band wastegate
Garret GT35r with .82a/r housing
Full-Race/PWR vertical feed intercooler
PRC intake manifold (type r)
Hondata intake manifold gasket
Hondata k-pro
RC 750cc Injectors
RSX Type S engine swap
2004 CRV K24 bottom end
Quaife LSD
Action 400ft-lb 2md clutch
Hasport mount kit
DSS custom axles
GE Head studs
GE Billet fuel rail
Aeromotive fuel pressure regulator, fuel filter and -8 a.n fuel lines and fittings
74mm Billet throttle body
Going with the k20/24 set-up with this swap. No one makes a simple low compression piston/rod combination for the k24 bottom to my knowledge so I am going with the stock block for the mean time. Swap should be done and completed early fall. I am shooting for 350whp/350ft-lbs.
Hondata k-pro
RC 750cc Injectors
Quaife LSD
Hasport mount kit
DSS custom axles
GE Head studs
GE Billet fuel rail
