1 - 6 of 6 Posts
car wont start unless i ground out pin e7 "Main relay" on ecu. e1 pin "fuel pump" is grounded aswell. does anyone have the pin out of a prc ecu so that the main relay gets ground with out manually grounding? car is a 03 rsx type s
Actually the above is wrong, it is 2005 model.
You need the 2002-2004 pinouts:
Andre
Also, if you need help with wiring it in and where it needs to go to, here is a simple diagram for a conversion harness:
1 - 6 of 6 Posts
