Any pics of what you had to reshape? I checked yesterday at the shop, but the line just seems too short to reach even if it was bent to what was needed.MikeW said:I would like to give some props to 6gearedteg, because everyone says the rsx powersteering line will not work but as he and i have found out during my dc2 swap that the stock line can be used it just needs a little reshaping to fit what your working with.
Reshaping is ok, but kinking the lines is the bad part. but if you don't feel like doing it. Do what I did, mark how you want it connected then take your original one off your car and take it to a hose shop, along with your k series hose and have them connected.Luder94 said:Any pics of what you had to reshape? I checked yesterday at the shop, but the line just seems too short to reach even if it was bent to what was needed.MikeW said:I would like to give some props to 6gearedteg, because everyone says the rsx powersteering line will not work but as he and i have found out during my dc2 swap that the stock line can be used it just needs a little reshaping to fit what your working with.
As for now, I'm most likely going to be doing what vuaccordla has done.
