1 - 4 of 4 Posts
Hey guys I ve drop in my motor k20a2 in my eg and I want to keep my p/s ! I mounted everything the reserve a the cooling oil but the thing is that the p/s rack with the the cross member is about 1/8of inch from the tranny !! SO DO YOU GUYS KNOW HOW I COULD FIX THAT Also Im using the stock radiator from the eg but I heard that I need the aluminum pipe that Hasport does with the drilled hole for the temp sensor and the fan switch but witch fan switch and witch temp sensor from the eg or the k20 ????? thanks :D
1 - 4 of 4 Posts
