1 - 20 of 44 Posts
there isnt alot of info out there on motor setups, bore/stroke, rotrex size etc
people tend to post some numbers but not much else
post your tips and tricks,,, best brackets, best routing options,, things youv
found work better or make things easier,, or more power etc
your motor setup and power numbers
pictures people love pictures
in for info. I want to go with a rotrex setup I am just not quite as familiar with a rotrex as I am with a turbo.
IMAKEBOOSTATIDLE
K24a4 bone stock
Stock a4 head
Rbc w/hr 70mm TB
3"
1200cc DPI injectors
C38-91
100mm sc pulley
376whp 310trq @ 7700rpms
stock block k24a3/20 ctr ep3, c38-61, 12psi, i, h, e. tts bracket, custom radiator, intercooler, piping. ~420hp/285lbft fly.
My old setup:
K24a1/k20a2
04 Type S Trans - stock
Rotrex c30-94 ~12psi
RBC with stock tb
Crush bent mild steel exhaust
650cc precision injectors
Tuned by Chunky made 377whp/250tq on Mainstream Performance's Dynojet.
Had a fuel issue and couldn't rev past 7,000rpm. That later got resolved and made what I estimate to be close to 400whp on 93 octane.
New setup improvements:
ITR chassis
C38-91
All In Fab header with 3 inch collector
Better exhaust (will be 3 inch and mandrel)
RSP intake manifold
DPI 1200cc injectors( plus entire fuel system upgrade)
E85 at some point
I don't know exactly what this will make but I see it hitting 500whp easily on E85 on a Dynojet.
'07 Si sedan
Kraftwerks kit C30-94 11psi
Stock block k20z3 with '08 TSX cams
2010 MDX TB
Buddy Club race header
3" exhaust
Deatschwerks Dw65c fuel pump
93 octane pump
Flaspro
Blue is basemap from Kraftwerks, Red is Tuned.
'07 Si sedan
2010 MDX TB
3" exhaust
93 octane pump
Flaspro
If you lower your vtec crossover to 3000 you will improve your low end a fair bit.
'07 Si sedan
2010 MDX TB
3" exhaust
93 octane pump
Flaspro
the beauty of a tune.. thats awesome
EG hatch
K24A3 ( Australian TSX version )
RBC intake manifold , 74mm Skunk2 TB
3 inch exhaust
JDMyard 4-2-1 header
Buddyclub valve springs,retainers,N+ cams
50 degree VTC
RC 1000cc injectors
98 octane fuel
KPRO ECU
TTS Rotrex c38 - 91
18 psi boost
373whp
K20a2 head (stock ports)
Supertech dual valve springs
09 TSX Intake camshaft + 09 VTC gear
K20a Exhaust camshaft
K24 bottom end (87.5x99)
Wiseco 11.0:1
Manley Turbo tuff
K20a Oil pump setup
Xcessive manifold
S90 70mm throttle body
ASP 4-1 Megaphone Header
3' Exhaust
2000cc FIC
Rotrex C38-91
Power est. 340kw atfw (465whp) 18psi @8500rpm
Video
Dyno Run
On track action
EG hatch
3 inch exhaust
50 degree VTC
RC 1000cc injectors
98 octane fuel
KPRO ECU
TTS Rotrex c38 - 91
18 psi boost
373whp
this is a super clean setup! :up:
EG hatch
3 inch exhaust
50 degree VTC
RC 1000cc injectors
98 octane fuel
KPRO ECU
TTS Rotrex c38 - 91
18 psi boost
373whp
any reason why the power was so low? seems at least 100whp lower then it should be
EG hatch
3 inch exhaust
50 degree VTC
RC 1000cc injectors
98 octane fuel
KPRO ECU
TTS Rotrex c38 - 91
18 psi boost
373whp
very nice built ! Any more pics of this track car ?
1 - 20 of 44 Posts
