Wow what the specs off all that's done in the bay?
03 Civic SI
K24 swap block sleeved by RS Machines Cali
K20A2 ported/polished match head and manifold
comp cams
9 1/2 Eagle rods
JE Pistons
polished crank
high volume oil pump
70mm throttle body
Cusco LSD (torque steers like crazy haha!!)
18" Rays Volk racing 2 piece wheels
16" Rotora drilled/slotted w/8 piston calipers (steel braided lines)
rolled fenders
AEM standalone
oversized aluminum radiator
intercooler off a R34
T70 .68 a/r trim turbo
CF hood/ back hatch
Exedy stage 3 clutch kit
Custom 3'' exhaust w/Blitz can
Tien adjustables
swapped front seats from an Acura tsx-s for looks and comfort!! The lumbar support is awesome
getting re-tuned once I swap out from a 2 bar to 3 bar map sensor and 8lb wastegate spring to a 12lb so I can safely increase boost. currently running 14lb on one tune and 17 on the other but I stick to the mild tune due to not being able to properly program higher than 15lb with the 2 bar sensor. even at 14lb it is a beast.
