1 - 2 of 2 Posts
/) ^3^(\ <- SO AWESOME!!
I was just looking at some ignition switches and learned that the 2000-01 Integras came with an immobilizer. Was wondering if anyone has attempted to wire this up with an ECU with the immobilizer feature enabled?
Might be cool to have a little extra security. :)
yes you can but you will need the transceiver and harness from any of these car. these have the same generation transponder-based immobilizer.
the transceiver is located at the tip of the key cylinder, and the harness is generally light green. theres also another harness right and its for key sense.
never done it but it should work.
if you can get uncut but programmed key from honda, get it lathed somewhere so it will fit into your teg's key cylinder.
1 - 2 of 2 Posts
