Hi guys,
After driving various N/A K24's for the past few years, we're stepping up to a higher competition in rallycross. This means we're developing a targeted >600hp K24 engine for our 4x4 rallycross car.
Since my experience in boosted applications is limited, I'm looking for your reviews/feedback/opinions on the proposed setup below.
Any input is greatly appreciated!
Car:
Full custom tube-frame chassis in CRX shell.
4x4 drivetrain, custom double wishbone suspension all round.
Longitudinal placed engine, sequential rallycross gearbox in centre of car (separate front/centre/rear plated diffs).
Targets:
600-650hp fly
boost treshold preferably before/around 4K
>600Nm/450lb-ft around 4.5K
approx. 550Nm/400lb-ft at 8K (8K redline)
Transient respons, minimising lag and keeping an eye on boost treshold are key. Yes, the sequential gearbox will theoretically allow the car to be between 6000-8000rpm all day, but the competitive nature of RX means the driver sometimes finds himself in the situation of accelerating from the corner at 4500rpm.
Fuel:
Dual bosch pump setup, return system
Homologated "pump" gas (RON 102, MON 90) so (r+m)/2= 96
Engine/choices:
Block/head K24A2
Cams K20A2 (or do we need aftermarket?)
Pistons: 9:1 or 10:1 CR?? 87.5mm
Rods: Manley's
Wastegate depending on turbo choice
Header built in house (twin scroll, ramhorn type)
Intercooler size TBD
Intake manifold: engine positioning means we're looking at skunk2 Ultra, since it's reversable. Will the street version be big enough for our power goals? The 90mm 3.5L race version feels like overkill to me.
Throttle body: what size do you guys recommend?
General/safety:
valvetrain supertech H-1021D (is this OK @ 30psi?)
3-stage drysump system
turbo after oiler
head studs ARP
gasket Cometic
bearings ACL
injectors ID1000 or greater if needed
downpipe+rest of system built in house (3.5-4")
clutch Tilton twin or triple plate
Control:
Motorsport ECU hooked to datalogging system
Boost control by ECU, any advice on control solenoids?
50* VTC, measured and pinned at max VTC
VTC/VTEC operational
Turbo's
Now, obviously for the million dollar question. We've played around with the EFR matchbot some but hoping for some experience from you.
Ball bearing, water cooled CHRA and TwinScroll are pretty much given.
I'm looking at:
GTX 3582R twinscroll 0.82 / 1.08
EFR 7670 twinscroll 1.05
EFR 8376 twinscroll 0.92iwg / 0.92 ewg / 1.05 ewg
I'm worried the 8376 might come on too late, can't quite decide on the differences between the 3582 and 7670. Although the EFR's feel a bit more developed with the GaTi turbines and the basic lack of TS housings from Garrett.
matchbot link: http://www.turbos.borgwarner.com/go/JJFPYZ
Again, any input is greatly appreciated.
thanks for reading!
kind regards,
Tom
Car:
Targets:
600-650hp fly
Fuel:
Engine/choices:
Block/head K24A2
Rods: Manley's
General/safety:
turbo after oiler
head studs ARP
gasket Cometic
bearings ACL
Control:
Turbo's
I'm looking at:
thanks for reading!
kind regards,
Tom
