1 - 6 of 6 Posts
looking for the part number for the plastic clips that hold wiring harness' to sheetmetal. the milky white ones that are basically a zip tie that pushes into a hole in sheetmetal.
91540-s30-003 im pretty sure thats what your looking for. its described as a 151.5 mm harness band. I ordered some a while back and they match your description.
thanks, checked hondaautomotive parts and found after i asked.
thanks for the reply on the black ones. will be calling honda tomorrow and ordering a bag full of them.
ok, looking for another clip. the brown clip that holds the harness across the back seat ledge on a 2000 civic coupe.
and lastly is the white clips that hold harness connectors to the body. found on abs plugs, plugs under the dash. ect.
its soo difficult to remove these without damaging them for re use.
Think it will just be easier to put these clips where i want them and attach the harness' as i need.
using these on my 2000 civic coupe doing a wire tuck and routing the s2k wiring for my rwd f22c swap. there is a thread in the 96-00 section.
1 - 6 of 6 Posts
