1 - 20 of 20 Posts
#2 said:
:up:
What are you using for the shifter?
stock rsx shifter box mounted from underneath...gotta figure out where the exhaust is gonna go now... :eek:
lookin good. so how far along are you. is it tuned, does it feel strong? good job bro
i haven't driven it yet...but it runs..This friday, i'll be able to work on it again and drive it.. :D
when you mount the shifter below does that change the whole exhaust piping? like where it goes.
Discussion Starter · #10 ·
I want to run it right under the box but the box hangs kinda low so i'm not sure what i'm gonna do for the exhaust. I'm probably gonna have to mount the box higher which will mean cutting the tunnel.
Discussion Starter · #12 ·
98specR said:
are you going to be running your center console? it looks like your shift knob is barely sicking out. you should just cut the tunnel.
I can, but yes it is very low. I didn't want to cut the tunnel but it looks like i'm gonna have to.
looks good, i like it alot. I should start my K-swap end of April. and have it done second or third week of may. :up:
Discussion Starter · #15 ·
Thanks man.
what kind of radiator did u use?
The stock ek radiator, just mounted it on the other side.
1 - 20 of 20 Posts
