Wow, just a question about the shifter plate, is that an accord or an RSX plate you are using? Looks like an RSX because the shifter seems really high up there...nikos said:
Is there any way you can put the plastic cover or some sort of cover for the center console over that shifter plate assembly?supafly said:You are right its RSX shifter box.
i'll take some measurements when I go to the shop after work.C-Zero said:Taqman lemme get the specs on that plate.
