u would have to do it twice in order to move the brackets closer together and you have fun w/ that buddy. This is a short throw and a shorter shaftmidoriek4 said:why buy when you can cut and weld the bitch![]()
Thanks, that looks good and I'm sure it makes a big difference99blackcivicsi said:I just rehosted the pic
huge differance in shaft lenght
... a shorter shaft, reaching down further for it.99blackcivicsi said:u would have to do it twice in order to move the brackets closer together and you have fun w/ that buddy. This is a short throw and a shorter shaftmidoriek4 said:why buy when you can cut and weld the bitch![]()
ah ic. so im hearing the best option is to go with the prelude shifter?supafly said:still have issues. Stick is the only thing that is shortened.
The plastic base is what causes the problems.
midoriek4 said:ah ic. so im hearing the best option is to go with the prelude shifter?
