there are many dif ways of putting a frank together - this is my build list for my K20/K24 RSX-S
K24A1 PARTS
complete short block
timing chain
timing chain cover
timing chain guides
oil pump chain & guides
timing chain tensioner
head gasket
crank position sensor
dip stick
serpentine belt
K20A2 PARTS
complete head
oil pump
crank baffel
oil pan
oil cooler
valve cover
crank pully
altenator
power steering pump
water pump / idler pulley
a/c compressor
knock sensor
oil pressure switch
drive axles
intake manifold
flywheel
clutch
pressure plate
engine harness
OTHER PARTS
PRB Hondata K-Pro
crv passenger side motor mount
oil cooler joint from S2000 ( allow you to run the k20a2 oil cooler without machining the block )
part #2 ( part # 11107-pt2-000 )
also get a tube of honda bond - and the crank pulley removal tool ( it will make life alot easier - Part # 07NAB-001040A & 07JAB-001020A )
K24A1 PARTS
timing chain
timing chain cover
timing chain guides
head gasket
dip stick
serpentine belt
K20A2 PARTS
complete head
oil pump
crank baffel
oil pan
oil cooler
valve cover
crank pully
altenator
power steering pump
a/c compressor
knock sensor
oil pressure switch
drive axles
intake manifold
flywheel
clutch
pressure plate
engine harness
OTHER PARTS
PRB Hondata K-Pro
