adjusted lashes, they were in pretty good shape except for the last cyl by the driver side ( cyl 2)
still runs rough but way better
now throws p0303
now throws p0303
Looks like your off a tooth on the cam gear pic. Granted it couldn't be that simple.still runs rough but way better
Cams are locked with pins in your first picture? I do agree, they look off a bit.how could it be off if the cams are locked
Am I misunderstanding you or are you confused with the cylinder numbering? Cylinder 1 is on the timing chain side, increasing sequentially to cylinder 4 on the trans side. The last cylinder on the driver's side is cylinder 4.last cyl by the driver side ( cyl 2)
You haven't touched injectors unless I'm missing something.already did, check out the opening post
Let us know. Keep in mind you came to bonce this off us. The angle of the pic the lighting, my butt itches can all effect the out come of our trying to help you. Being a tooth off can happen to anybody. So can not properly locking in the VTC. Not that hard to lock it in and what are the odds of it moving once it's locked?I'll fix it tomorrow
I read that putting a dollar bill behind the muffler - that if it sucks and holds it in, its bad valvesOk. Sorry.. WTH is the dollar bill test lol?
