amazing writeup brian!!! i'm glad to see everything worked out for you. looks great:up: .
have you gotten your motor dynoed since you put on the p/s?
EGfrank said:What about using the ep3 pulley that we all already have?
RIGHT ON!! I KNEW IT COULD BE DONE!! THANK YOU BRIAN FOR SETTING THE PACE!! :up: :up: K-SWAP EG WITH POWER STEERING!!!!! SWEET!!!Paul1985 said:So if i have an EG that has P/S in it from factory, when adding a K-swap i would need:
K20A PS Pump
JR Pulley
52" ribbed belt
02-04 RSX High pressure hose
Fluid return
Is that all that would be needed and do you know what part(s) would be needed for a stock fluid return?
Thats the pressure switch. I believe is for the ELD (electrical load detector) It rises the rpm some when it sense you turning it so that it does bog down to much during idle. Its your choice to hook it up, but so far I haven't notice any major rpm drops and works fine for me without it hooked up. I believe k pro uses the p/s ELD pin on the ecu for something, correct me if i'm wrong on that peeps.Nevaeh Speed said:What about this plug thats not hooked up. WTF does it do...
Pimp ass write BTW.
I believe you can use the 02-04 civic high pressure line as well. only difference is that switch on the civic hard line is located where the line transitions from rubber tube to hard line. But that will need to be confirmed...k-dub said:Thats the pressure switch. I believe is for the ELD (electrical load detector) It rises the rpm some when it sense you turning it so that it does bog down to much during idle. Its your choice to hook it up, but so far I haven't notice any major rpm drops and works fine for me without it hooked up. I believe k pro uses the p/s ELD pin on the ecu for something, correct me if i'm wrong on that peeps.
mine is wired up, and it works great:up: .k-dub said:Thats the pressure switch. I believe is for the ELD (electrical load detector) It rises the rpm some when it sense you turning it so that it does bog down to much during idle. Its your choice to hook it up, but so far I haven't notice any major rpm drops and works fine for me without it hooked up. I believe k pro uses the p/s ELD pin on the ecu for something, correct me if i'm wrong on that peeps.
Not until I slap on the R-Crew header, k-pro, and an exhaust bigger than 2.25". I probably won't compare the difference in power just by adding the P/S. I'm too cheap...98specR said:amazing writeup brian!!! i'm glad to see everything worked out for you. looks great:up: .
A good notching still has to be done for the P/S pump itself on the EG hood. The DC2 hood has more clearance, but I don't know if it is enough to not have to notch anything. Even if you got the pulley, the pump will be your biggest concern. Since you probably have a pump, or since they are easy to obtain with all those who remove them, I'd recommend testing one of those out with the stock pulley removed. If you can clear the pump, the Jackson pulley will work out for you, as its diameter is smaller than the pump's.NtegraDryvr said:Looks great! I'm doin a k24 swap into a DC2, do you think using the JRacing pulley would clear my hood so I wouldn't have to cut webbing or raise the good?
Yep, that would be all you need!Paul1985 said:great write-up Brian!
And great find with that pulley.
K20A PS Pump
JR Pulley
52" ribbed belt
Fluid return
Its great someone has finally covered this PS issue, thanks Brian!!
:up: :up:
You still might have to notch the hood for the P/S pump itself, but I'm not certain on that. The pulley is $80 from Jackson Racing.drhonda said:Nice job :up:
I bet you could use that pulley on an ek and not have to notch the hood. what does that pulley run? Nice job bro.
K-Dub answered that, but just a comment: Because the Jackson Racing pulley is smaller in diameter, you are actually already spinning the pump faster for a given rpm. So when I'm trying to parallel park or whatever (at idle or low rpm), I can do that w/ my pinky finger as is. I could have wired it up, but I'm leaving it as is becasue of this fact.Nevaeh Speed said:What about this plug thats not hooked up. WTF does it do...
The bar is for a US ITR... 24mm. The parts are easily obtainable! Hit up S.W.A.P. (SOUTH COAST PERFORMANCE - ACURA DEALERSHIP), sponsor of this site!Cookie said:RIGHT ON!! I KNEW IT COULD BE DONE!! THANK YOU BRIAN FOR SETTING THE PACE!! :up: :up: K-SWAP EG WITH POWER STEERING!!!!! SWEET!!!
What is the diameter on the ITR front bar? Looks like 28m? :wow:
How obtainable are those ITR carriers that would be needed to run that phat bar? :up: :up
Most P/S systems have some form of oil cooling. A stock Civic or Integra w/ P/S has just a long routing system to help cool the fluid, and most additionally have an oil cooler of a much cheesier form (a loop of hard piping that sits right in front of the radiator for cooling) than what I had used. There are many ill effects that may occur if not using a cooler (i.e. reaching the boiling point of the fluid, melting the rack seals, inconsistent steering feel...etc.).poyo said:Brian, you ARE the MAN!!! The Man of SuperWith Mad :dance: Skills!!! Now I need to re-read them all over again? Jeez, I'm such a noob! Mind telling us why use the oil cooler?
