1 - 5 of 5 Posts
Ok I have a 2002 ep3 and o ly half the dash lights work. Like I can see the tach but only half the speedo and from there over non of the lights work all the way over to the ac and heat knobs. I have checked every fuse in the car that I know of. About to drive me nuts please help.
There is a trace on the board for the gauge cluster, it is probably fried. Seems to be fairly common especially if a aftermarket headunit is installed. A jumper wire can be soldered onto the board to bypass the damaged section
Do you have a write up or any pics or anything on this? or if i pull my cluster apart should i be able to figure it out?
1 - 5 of 5 Posts
