1 - 2 of 2 Posts
I am going to start a post with all the questions that i receive in Emails and PMs as well as all the replies. Feel free to post here as well as the other ways available to communicate with Hybrid Racing.
Thanks,
Will
Discussion Starter · #2 ·
hey i was wondering if you could answer some of these questions on the k20a swap, basically just wondering what these parts are for and why they are needed:
3 Bracket 31175-pra-000 $39.96
7 Pulley 31190-pra-000 $22.61
5 Bearing 31185-pcx-003 $5.14
12 Bolt 10 by 25 90031-pra-000 $1.48
Thermo unit $21.85
97 cable $22.53
Switch Coolant $25.99
97 cable? 12 bolts go where? bearings for what? pulleys don't come with the motor already? Brackets for what the radiator or something else? thermo unit and switch coolant? doesn't those two come with the motor already? Other then that great post!!!
thanks,
The bracket, pulley, bearing, and bolt are needed to remove the Power steering from your K series motor. Here is a picture to show you how the parts work.
This pulley setup is not needed on any motor that came from the EP3 Civic.
The Thermo Unit and Coolant Switch are used to control the fan and the temp gauge in your chosen chassis.
The remaining part is the throttle cable and this is used for throttle body actuation.
Let me know if you have any other questions.
Thanks,
William Davidson
www.hybrid-racing.com
1-985-951-8588
1 - 2 of 2 Posts
