So in light of my EG being taken too far to the right and it doesn't like the cold weather now because of the tune (I'm just tired of driving an hour to do retuned) I thought I would do an EK build. Yes, and not turbo it!!
My intentions for this build won't be as bling but still with quality parts.
I first had to start with a 3 week adventure of finding a true clean title EK hatch that was either white or silver.
And I have a time of parts already.
I'm going with the Hasport EKK2 and I'll be using an eg subframe with manual rack. I have the hardrace front control arms, inner and outer tie rods, rear trailing arm pillow bushing, front and rear camber kits, toe kit and center roll adjusters.
I'm going to install the circuit hero oil pan baffle and timing chain guid. I also bought the CSF full radiator (it's supposed to be a "drop in").
I also went with Karcepts ac/ps delete kit, fuel rail, 36mm hubs, clutch line and shifter plate.
Action clutch stage 4 with ligh flywheel. Also a Mfactory LSD.
Of course Kpro version 4 and heat shield.
Rcrew header, bolt boys mount hardware and chassis kit.
As well as some stuff I'm not mentioning.
