Found one S2000 f20 with boltons measured on Bapro 254hp. Interesting to see how it stacks up against my cl9 as they make same top end power.
Was the F20C1 measurement rated at flywheel? Around 230 Nm from 7000-8000 rpm would be quite good.Found one S2000 f20 with boltons measured on Bapro 254hp. Interesting to see how it stacks up against my cl9 as they make same top end power.
The torque shape of the K20 looks like stock, despite VTEC is a bit late, but not beyond 7500 rpm. What are the modifications on each of them?EP3 vs Accord R 2.2. K20 vs h22. Same dyno same day.
What was your max ignition approx. in wot with 100 ron?Κ24/Κ20 12.7CR
4 2 1 ex header
Ported Rrc in.Manifold.
70mm throttle body s90
76mm exhaust
Prb k20a2 head porting valves ..
Toda Racing spec E camshafts.
100Ron gas
Very happy with cams !!
Chassis ep3 type R
Bonus 100-200km
I sell toda cams because i replace my project turbo.
Toda cams & valve springs
Has only 200km. In perfect condition Are brand new. tested only dyno and little road Makes 322 horsepower and 300nm torque on k24 12.5CR Very friendly to valvetrane...onwww.k20a.org
Woah, do you have any video uploaded of that car?Κ24/Κ20 12.7CR
4 2 1 ex header
76mm exhaust
100Ron gas
Chassis ep3 type R
Fucking awesome.
Thanks mate.Fucking awesome.
Could you tell the weight and more or less rest the setup of the car (tires, aero, etc.).
I’ve also got an ep3 and It’ll probably have a k24 inside in the future
Thanks mate.
Chassis 950kg
Cams toda spec E
change 17" wheels to 15" volk rays .tires 19-55/R15 semi yokohama a052.
now replaced to 225-50/R15 R888R because 195 width was little dangerous..car went extremely right & left
