the primary o2 is a wideband o2. the ecu requires it. if you don't have one you engine won't run right if it runs at all.Dark2k1 said:What will happen if i don't have a A2 first o2 sensor ?
huh? The motor will start and run fine. It'll just throw a code and run in open loop.2fastxeg said:the motor wont even start up..
