I stuck with them for both reasons really. You can read 100 things about building motors and the parts people sell but until you instal them yourself and cherck them all you never can be sure. Plus everything on the market is for a K20A2 not the JDM K20A, we didn't know if there would be any issues so we decided to play it safe on the clearance..
You might also find that on a K20 that oversized valves along with bigger ports will actually hurt the perfromance, due to there being to much air-fuel in the chambers. The exhaust would probably benefit the most from the valves being 1mm bigger, but I doubt the inlet would make alot of difference.
But once again, you really need to check the clearances of the stock parts before you go bigger, just to be on the safe side.. I know with B-series Valves you cant mill the heads with alot of oversized valves etc..
