1 - 1 of 1 Posts
I'm helping a buddy here with a broken laptop sell his track car. He has moved on to other things and the car is taking up space in his garage. If you're interested, email him, not me at [email protected]
Mods:
Drag one piece suspension
BWR lower control arms
Beaks bar
Xenocron rear speed sensor setup
Race spec ignition/power system
Race spec coil pack harness
Custom fuse panel so the car doesn't use nor need an interior harness
Also has switch panel
10 pt certified caged
Window net
Parachute
Custom 3 piece frame & belly pan with push pins
5 gallon FCS tank also comes with
Hasport B series mounts with billet inserts
Custom traction bar with battery mount
Also able to add lead inside for weight
Also has a lot of mods that arent listed that are coming with the car.
1 - 1 of 1 Posts
