1 - 8 of 8 Posts
im about to install nitrous on my k24 allmotor setup and was confused with the wiring diagrams etc.
Need some really layman explanations to what the terms means?
1- arming switch input
would this act as a on and off switch which one can install near the steering etc which would let the ecu know that one is ready to run the nitrous?
2- which input (e20-e22 etc etc ) should we run this into?
3- what does invert input means?
4- Output control switch
would this be the switch which activates the nitrous solenoid when the nitrous parameters are met?
5- whats GND on/off means?
6- can we connect to any of the input/output connectors shown in the parameters or just stick to those which other users on here have worked with?
Yes, i believe your switch sends a ground to the ECU, so you need the switch you use to arm the nitrous to a ground.
You need to look up the wiring pins for the E plug and wire to e20- e22
Say your switch you use to arm the nitrous sends a ground to the ECU to arm it. When you invert it, the nitrous will arm without ground. hard to explain. But when you wire everything and you flip your switch to "on" it inverts it, so when you flip your switch to "off" that's what arms it..
Yes
You can use any listed, i wouldn't use the ELD though. save that for a wideband incase you use it i the future.
Also, stick to Hondata's wiring diagram. DO NOT look up relay wiring diagrams on the net, the ECU sends a ground to the relay activating it
the relays i have seen online here have the pins clearly stated as 30/85/86 etc but the relays available here locally are does not have those indicators,what to do now?
i have the nitrous installed mechanically,only the wiring part is left :wwhat:
Discussion Starter · #8 ·
found the relay from a local electric store :new_slayer: would begin wiring the nitrous on sunday with the help of a friend and post which diagram works for me :new_slayer:
1 - 8 of 8 Posts
