1 - 11 of 11 Posts
i was wondering what everyone thought about a built k20a2 dyno'ing at 267 with skunk2 stg2 cams valve train rods and 12.5:1 compression pistons? i was thinking maybe a 100 shot but i dont know if my cpr is too high for nawz
start with a 70 or 75 shot if you are not on race gas or E85.
with 12.5:1 compression a 75 shot will feel like a 100 shot, nitrous reacts good to high compression but the gas being used is what dictate how big of a shot you would be able to run safely if you want the engine to last you longer. remember to use colder spark plugs.
650cc should do for c16, c12 race gas or 93 pump gas that size gives you room for bigger shots down the line but with a 70 shot 550cc should work fine.
Way bigger than that 650cc should be really close to maxed out. He should be in the 330hp/300tq easily++ with 75-100 shot duty cycle will be pretty high. He MIGHT get away with 650s on race gas but on pump theyll be maxed out.
yeah i ran the math for a stock type-s head so didn't notice how many horses he had all motor with cams but 650cc will do with a 70/75 shot & at least 750cc if your going with a 100 shot with fuel at 55psi.
are those WHP? what kind of dyno. seems high for some reason for a 2.0l & what size injectors do you have now?
if going for the big shot only use race gas & a professional tune.
IMAKEBOOSTATIDLE
i have a k24 on dynapack it put down 280hp 222trq... 12.5:1 compression with 440cc injectors right now.
i was thinking a 125 shot Dual stage in 3rd and 4th.... would only use on 100octane race gas tuned for it as well.... im on kpro too
or I was thinking a Kraftwerks Supercharger
1 - 11 of 11 Posts
