I was snooping around the fast brakes website, and if you go to new products youll find they sell the new quaife quick ratio steering rack for the 92-95 civic/del sol/integra and 88-91 civic/crx. According to the fastbrakes website it will convert your car from 4.2 to 3.2 turns lock to lock, all for $230 dollars. Well after practically shitting my pants, I jumped over to the quaife website to look for more details, and I found on their 2004 pricelist that the 88-91 setup is 3.2 turns, while the 92-95 setup is actually 2.8 turns. This means you will have less than 1.5 turns in either direction! Thinking this was too good to be true, I e-mailed quaife, and asked if this was a complete steering rack, or just a kit to rebuild your existing rack. Sure enough, you will have to rebuild your steering rack. Next I cousulted the Helms to see just how difficult a task this would be, and it actually seems pretty mild. There are only two special tools needed (one is a poll pin punch to set a lock washer, and the other is a special driver to seat the new pinion shaft). The hardest part seems to be droping the shift linkage to remove the steering gearbox.
I just though I would share this with you guys. I am waiting for another e-mail reply from quaife about instructions, and few more details, so I'll keep you informed...
