1 - 9 of 9 Posts
Hello everyone, just thought id say hi.
I have an all motor K20a in a 92 hatch, went 11.31 @ 120.
I have built the car on my own budget and only have about 8 passes on it with no dyno tuning. Hopefully that will change this year...looking to get into the 10's someday.
I also have a k24 block that is being built to step into the turbo classes next season.
anyway, just wanted to say hi.
Reid
non vtec said:
Hey congrates on the times..
What sort of 60fts do you run and tyres??
also what trans?
I read that you run VTC killer cam gears aswell with your old B-series stand alone..
Good luck on the coming season..
Hopefully I can beat you to the 10's
Heres what I got...
K20a
Stock manifold w/ 70mm BBk TB(got 50mm ITB's for this season)
toda spec c cams, VTC elimination and VTC gears, port work
rods, pistons, lightened crank
toda flywheel, act clutch
stock trans, stock diff
26x8.5 MT tires(too big)
SDS management(its all I had to work with)
car @ 1800 lbs w/ me in it
low 1.6 60ft's
sweet thats pretty cool. abit more than my set-up but pretty close.
I hope you run your 10's the more K's in the 10's the better.
I'm still running a stock motor but I've got a ton of Crower parts in transit at the moment hopefully have run a 10 by the 6th of march..
Banned
Welcome to the site. Thanks for joining, I remember your car from honda tech. You have that white one if I remember correctly...
I guess I need to make a drag section next.. :)
Nikos
Discussion Starter · #8 ·
Nikos
Nope, the white one is another guy from my area. He is running a B18, my car is a copper color. Somewhere on honda tech is the video of the 11.31 pass.
1 - 9 of 9 Posts
