1 - 20 of 30 Posts
· Banned
Well, this morning I wasted some time looking at online honda/acura dealerships for K series parts. hondaautomotiveparts.org acuraautomotiveparts.net etc...
These is what I found:
THESE ARE NEW HONDA/ACURA PARTS FROM online DEALERS:
ACURA RSX TYPE S K20A2
ENGINE HARNESS: $245
SUBHARNESS FOR BATTERY: $86
COMPLETE HEAD: $2800
COMPLETE TRANNY: $3800
COMPLETE SHORT BLOCK: $2900
BARE HEAD : $1318
VALVE COVER: $167
TRANNY CASE : $250
INTAKE MANIFOLD : $292
WATER PUMP: $99
MASTER CYLINDER : $218
BARE BLOCK: $1500
OIL PAN: $172
CRANK $632
ECU: $555
SHIFTER: $81 without knob
TRANNY CABLES : $255 ( FOR ONE OR TWO.. NOT CLEAR)
ACURA TSX K24A
CRANK: $700
COMPLETE HEAD :$3400
COMPLETE SHORT BLOCK : $3400
BARE HEAD : $1237
BARE BLOCK: $1400
HONDA ACCORD K24A
BARE BLOCK $400
COMPLETE SHORT BLOCK : $1180
CRANK: $622
H20 PUMP: $84
HONDA CR-V K24A
BARE BLOCK $1384
COMPLETE BLOCK: $2650
HONDA ELEMENT K24A
BLOCK $400
COMPLETE SHORT : $1200
CRANK $622
say i just needed a bare head right since im gonna be putting aftermarket parts in it anyways, do i still need to buy all the bolt flanges, o ring, pin dowel, sensor assy, shaft rocker.... etc... you guys get my point? same for the block?
· Banned
Discussion Starter · #15 ·
BoostedEH said:
what about 06 si intake manifold
$161 from online honda dealer..
I need to update this list.. There are a lot of parts that are now cheaper because of the 2006 Honda Civic Si...
rockers, bolts, chains, alternators, valve covers, crank pulleys and so much more are much cheaper...
For example... 2006 Civic Si crank pulley is $69 from online honda dealer...compared to 89.79 (acura rsx type s)
· Banned
Discussion Starter · #19 ·
jza25ef said:
nikos: the Subharness, would that also connect to the alternator, knock sensor and starter (charge harness) is this the same?
Not sure what you are asking.. Yes, the subharness from a honda ep3 (2003 Civic Si) will connect the alternator, knock sensor and starter...
Charging harness = subharness
ECU: $555
Thanks for posting this info. Now all I need to know is which online dealers I can find these parts from, at these prices???
I need to buy the OEM engine harness and ECU, and I don't want to buy them used.
btw - I'm buying an Ariel Atom with a K20A2 in it, but its got an aftermarket MBE ECU, and I'm going to switch that to OEM/Hondata. That should insure that it'll pass smog here in Calif., right?
1 - 20 of 30 Posts
