well mine produced 206whp&144ft lbs. with an intake and DTRFAB header, with 2 cel, one was for o2. with no hondata. no tuning whatsoever. with the hondata and the o2 fixed, i plan to make 220+whp.non vtec said:I dunno about that, The dyno we used is the most accurate we have, Plus we dont play around with drive loss's etc..
if you cant compare dyno numbers, there would be no comparisons whatsoever. so that really doesnt make sense. thats like saying that you dont know if your car makes that much power, because a dyno is not accurate enough. its like saying you wouldnt notice your gains from i/h/e because you cant compare it to your stock dyno numbers. :?: :idea:non vtec said:In all your years of looking at this stuff have you not realised that you cant compare Dyno numbers.. Its just a tuning tool thats all.....
I plan to have gone from a 12.43 @ 110-111mph to a 11.2 @ ???yet
But good luck with making 220whp...
i know what your saying. i thought you would have made more power none the less though. and dynapacks read a lil higher than dyno jets if i remember correctly. it just seems you could be making more power. you do have a k20a right?non vtec said:No you can compare dyno stats from the same dyno using the same calibrations... .
non vtec said:yeah I have a K20A I am actually making more power than a circuit DC5R that runs a intake, toda header, exhaust and a K-Pro so I'm not complaining and also if I go out and run a low 11 with only 215whp that makes it more impressive...
As a side note on the Dyno. The dynapack we used is closest to the lowest reading dyno in N.Z.
