New DGauge now available!
8041 Views 44 Replies 17 Participants Last post by  Brock
The new DGauge from Brockway Engineering is now available!
The DGauge is a digital multi-gauge that plugs into the diagnostic port on most 1996 and later Asian, European and some US vehicles and displays real-time engine data on it's color TFT LCD. Through the selection of one of 3 different screen modes, you can monitor 2 or 4 user selectable parameters at a time. As many as 25 different parameters are available for viewing, depending on vehicle support and 7 parameters via external sensors. Exceptionally easy to set up and operate. With unmatched performance and reliability, the DGauge offers the most advanced technology in engine monitoring.
100% compatible with all K-Series applications utilizing the factory ECU.
100% compatible with K-Pro. Monitor A/F ratio, engine temp, boost and more.
Supported vehicle parameters:
STF (Short Term Fuel Trim) %
LTF (Long Term Fuel Trim) %
CLV (Calculated Load Value) %
ALV (Absolute Load Value) %
RPM (Engine RPM)
IGN (Ignition Timing) °
TPS (Throttle Position Sensor) %
MAP (Manifold Absolute Pressure) kPa
BP (Boost Pressure) kPa or psi
MAF (Mass Air Flow) g/s
ECT (Engine Coolant Temperature) °F or °C
EOT (Engine Oil Temperature) °F or °C
IAT (Intake Air Temperature) °F or °C
AAT (Ambient Air Temperature) °F or °C
O2 (Oxygen Sensor Voltage) v (Bank1 and Bank2)
AFR (A/F Ratio) (Bank1 and Bank2)
ALC (Fuel Alcohol Level) %
VSS (Vehicle Speed Sensor) mph or km/h
BAT (Battery Voltage) v
FRP (Fuel Rail Pressure) kPa or psi
GR (Gear Position) 1,2,3,4,5,6
* Some parameters not available on all vehicles.
Supported external sensor parameters:
AFR (A/F Ratio)
EGT (Exhaust Gas Temperature) °F or °C
OIL (Oil Pressure) kPa or psi
Features:
• 3 screen modes that allow the user to select the data displayed.
• Selectable color for each "Gauge".
• Speed and Temperature can be displayed in Metric or English units.
• Pressure can be displayed in kPa or psi.
• Reads and clears diagnostic trouble codes (DTC's).
• Turns off check engine light (CEL).
• Displays boost on vehicles equipped with a MAP sensor.
• Displays A/F ratio on vehicles equipped with an OEM wideband O2 sensor.
• 2 external sensor inputs.
• Programmable shift light output.
• Adjustable ECT, EOT, EGT, BP and OIL alerts.
• Adjustable LCD brightness.
• Fast update rate.
• Data output for logging.
• Updatable Firmware.
• Simple Plug and Play installation with included Data Link cable.
• Advanced high reliability 3" TFT LCD. Readable in direct sunlight.
• Automotive grade components used throughout.
• Compact size (5.2"x 2.2"x0.75"). Includes mounting brackets.
• A/F ratio conversion for Honda/Acura K20 engines built from 2002 to 2003. Vehicles with these engines have wideband A/F sensors but do not report the A/F ratio via the standard PID for A/F ratio and must be converted from the O2 sensor voltage. Accuracy is within a tenth of a point (0.1) from 11.5:1 to 15.5:1 A/F ratio. It will read richer and leaner mixtures, however the conversion is less accurate as the A/F ratio moves out of this range.
Options:
Shift Light - The shift light output is adjustable from 3,000 rpm to 9,900 rpm in 100 rpm increments. The output can drive an LED shift light such as the SL2A (sold separately).
External Sensors - The DGauge has 2 external sensor inputs. Sensors and sensor connection cables are sold separately.
See website for complete details and demo video:
http://www.brockwayengineering.com/dgauge.html
41 - 45 of 45 Posts
sorry for lagging on the pics. still trying to work out some non dgauge kinks. i've had the dgauge for 4 months now and it works flawlessly
:up:
how do u get it to work with a 96-00 civic with a obd1 conversion harness?? or will this work with the obd1 ecu?
plugs into OBDII port.....
The DGauge only supports OBD2 ECUs. So an OBD1 ECU will not work.
41 - 45 of 45 Posts
