1 - 8 of 8 Posts
The middle sensor is the TPS.
Cost used if you can find one is about 250.00.
Dealer sells on the TB for 898.00 that has all sensors. Ill have to see what the others are.
Used is definently the way to go if you can find one. The other choice is to by the IACV (rotary valve) and purge control solenoid separately, then buy an Element t-body and remove the TPS and use it on yor t-body. That gets the price under $400.
brian g
anjapower said:
K20A2 EH2 said:
Can anybody tell me if the sensor on the bottom is the IACV for sure? I really need to know so i can order these parts.
that's the IACV, the one right next to the throttle body (diagonally angled downward) is the TP sensor.
Thanks man. I knew what the TPS was , but was unsure about the IACV. Really sucks that the only sensor i can salvage is the Map, but oh well.
brian g said:
Used is definently the way to go if you can find one. The other choice is to by the IACV (rotary valve) and purge control solenoid separately, then buy an Element t-body and remove the TPS and use it on your t-body. That gets the price under $400.
Thanks brian.
I had planned on trying to find a used one from a recycle yard before i went for the steep dealer pricing. If that doesn't work out then i'm definitely going with your suggestion.
supafly said:
If you get a new harness Im interested in the cut one.
That is most likely the route i'm going to take. I'd much rather just get one from acura instead of trying to piece this one back together. Just PM me. :)
1 - 8 of 8 Posts
