1 - 18 of 18 Posts
basically I need a crankshaft. I spun a rod bearing and after I measured out the crank journals they are to far out of spec to think about sending it to a shop, so I need one. Also I can do a short block (crank, rods, pistons, bearings, etc)
please text me at 704,651,506seven (I DONT GET ON HERE MUCH) and let me know.
I live in VA looking for k20 mainly but if some torque comes across my way (K24 :D )I'll consider it. so offer up!!
I have a k20a2 block,with 12:1 je pistons bc rods arp rod bolt need some stuff text me at 7407018447
How about a base rsx or a Si ep3. Will that work. I also have a z3 rods piston crank I took out of a runnin z3
basically I need a short block (crank, rods, pistons, bearings, etc) please text me at 704,651,506seven and let me know. I live in VA looking for k20 k24 so offer up.
I have an Mint k20a2 type s short Block <50k miles...missing oilpan and pump only... i used them for my k24 swap...the oilcooler is still there as well as all chains, guides, screws etc.. 550 shipped lmk
Discussion Starter #11
can you send pics either in pm or I can email you. my phone screen is all scratched up
thats only for that one block correct?? or you have to change the piston for every set up.
Yeah. The k24a1 and k24a2 blocks can just have a k20 head on them with their stock internals, no P2V contact. Just make sure clearances etc are good for a peace of mind:up:
1 - 18 of 18 Posts
